Our camera is not picking up animals. Sensitivity is set at 100.
- What animals in particular?
- How large are they?
- How close are they to the camera?
Our cat is about 10 lbs. The camera is about 12 feet away. It picks him up 2 out of 10 times he comes on our deck.
We also have a 17 lb dog and it misses picking her up sometimes.
The detection range for the essential is spec'd at 7 m (23 feet). But I believe that is assuming people, not small animals.
Note that the sensitivity is set in the camera rule- the sensitivity in the motion detection test is not saved, and is just for the test.
The detection is best for things at the bottom of the field of view - likely the case for you, but that might depend on exactly how the camera is aimed. It also works best for motion across the field of view - so less effective if the animal moves directly towards the camera.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
