AVD2001Aer1.2 KEEPS GOING OFFLINE
Just installed AVD2001Aer1.2 and its constantly going offline. It will detect motion and notify if someone approaches but it wont show live view. Sometimes it will just come back on or I have to go and disconnect the battery and pug it back in. WiFi connection is good. Either way its very annoying that I cant find a solution on Arlo's so called support. ( does not exist
) Any suggestions would be greatly appreciated.
Thank You
This may be a signal strength/quality issue. What is the house construction? Stucco, brick and stone are the worst at blocking the signal. How far away is the router and how many walls, etc. are in the straight line path? What's on or in the walls that could block the signal? Are there any wireless devices, not just WiFi, that use the 2.4GHz band nearby? If you temporarily take the doorbell just inside the door does it work properly?
I have tried to bring the unit right next to the router and it says connected but its not operating.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
