  • 1 Reply
  • 267 Views
diegomax
I used both routines of the software.
The problem is that if I am away for several days, my cameras turn on "active during absence" (which I want), but since I also have a day/night routine, as soon as night arrives it switches to day/night mode (it therefore turns on "active during presence") and as soon as morning comes it switches to "sleep mode". Then I have to restart the "active during absence" mode from my vacation site.
How can I make the "geolocation" mode "stronger" than the day/night modes?
@diegomax wrote:
J'ai utilisé les deux routines du logiciel.
Le problème est que si je suis absent plusieurs jours, mes caméras se mettent en "activer en absence" ( ce que je veux) mais comme j'ai aussi une routine jour/nuit, dès que le nuit arrive elle passe en mode jour/nuit (elle se met donc en "activer en présence") et dès le matin elle passe en mode "veille". Il faut alors que, depuis mon site de vacances, je relance le mode "activer en absence"
Comment fair pour que le mode "géolocalisation" soit "plus fort" que les modes jour/nuit ?
Normally I recommend reserving "Arm Away" for use when you are away.  And then set up the schedule to shift between "Arm Home" and "Standby".
One simple thing you can do while you are away - just disable the schedule automations in the Arm Away mode.
  • 1 Reply
  • 267 Views
