Deleting Local Feed Clips off iPhone
  • 508 Views
elwobot
I'm working with No Arlo Plan.
In my feed, local section, I see motion alerts with clips. I can download the clips. However, I don't see any options to delete the clips from my iPhone. I tried swiping left. In a clip, I get the option to "Share" and "Save to Photos" so I assume that the clip is stored elsewhere. I don't see the clip in my Photos app. In the Settings app, I don't see the option to give Arlo Secure access to Photos.
How do I delete specific or all local feed clips from my iPhone?
Are you using Android or iOS?
With iOS, the only way I know to do that is to uninstall and then reinstall the app.   Which is annoying, it'd be useful if Arlo provided a better way.  @BrookeN , @ShayneS , @JamesC - can you see if this is on the requested feature list?
With Android, I believe can go into the OS storage settings and delete the data and cache.  But iOS doesn't give controls to do that.
elwobot
I'm on iOS.
Right, that is pretty annoying. Hopefully a better way is added. Thanks anyways!!
BrookeN
It is in as a feature request. I will update the community if there is any changes regarding this.
  • 509 Views
