Can’t connect to Home Kit.
  • 6 Replies
  • 1148 Views
Orrefors
I can not connect base to home kit.
I think I need a code that several users have asked for.
thanks
ShayneS
Thank you
6 REPLIES 6
Actually you need Arlo do to a token reset for you (there is no code).
Orrefors
Ah ok. I hope they see this then 😜
I'll tag them for you, just to be sure:  @BrookeN , @JamesC , @ShayneS
It might take a few days - forum coverage tends to be lighter during the holidays.  If you have a subscription, you can also try reaching out to Arlo support (using the support center in the app).  They can also reset the token.
ShayneS
Thank you
Orrefors
Perfect, that fixed it.
ShayneS
Thanks for the update!
  • 6 Replies
  • 1149 Views
