Adding arlo essential 2k cameras to Arlo 2 base
  • 1 Reply
  • 180 Views
Pollypie
Can I add Arlo essential 3rd generation to a Arlo 2 setup profile?
Not sure what you mean.  You do need to select the correct camera model when doing the install.
Arlo hub compatibility info is here:
Though the Essential cameras can also be directly connected to your home wifi.
If you are talking about Pro 2 cameras (not Essential 2nd gen), then hopefully you are aware that all currently sold Arlo cameras require a subscription for cloud storage.
  • 1 Reply
  • 181 Views
