Arlo pan and tilt keeps losing home position
  • 4 Replies
  • 30 Views
Importsport
I purchased the outdoor arlo pan and tilt 2k and I really like the features, however it keeps losing the home position every day. I've done the motor calibration several times. I have to manually go in the app and reset the home position and several saved positions everyday. It will work fine for a while then when my car pulls in the driveway it will tilt down and never return to the home position. This is really annoying to find the camera pointing down and not recording anything going on at the normal home position setting which has a bigger field of view of my property. Do I have a dud? Any help would be appreciated.
The first step would be to remove/reset/reinstall the camera top see if that helps.
Importsport
Will do 👍, I will update with the result when it gets done.
Edinburgh_lad1
It's to do the mode you're keeping the camera in. In Standby, it'll tilt down.
Importsport
The camera is in armed mode, I don't even know how to activate standby? Shouldn't it go to the default position after time anyway?
  • 4 Replies
  • 31 Views
