essential XL wont connect to new modem
  • 1 Reply
  • 1276 Views
Cobra173
had it working perfectly connected to TP Link, had a new modem now it wont connect ?, all other devices are connected and working well ,
The simplest migration (for all your devices) is to set the network name and password on the new wifi system to match the old one.  Then there is no need to change the configuration on your various devices.
You could still try that.
Otherwise, try removing the camera from the account, doing the hardware reset (with the pairing button), and then adding the camera back.
