charge cables
  • 5 Replies
  • 5327 Views
smallfarm
i want to use a shorter charging cord that is also not white . where can i get one that will work with 2K cameras?
@smallfarm wrote:
just the cable, I have the plug (indoor) and around 6,8 feet would be good thanks!
Assuming indoor use, any 6 foot USB-C cable will work for the Gen 2 Essential models.  Since it is only for power, USB 2.0 is fine.
Of course get USB-C to USB-A if the charger only accepts USB-A.
5 REPLIES 5
Do you mean an outdoor charger?  Or just the cable?
What length are you looking for?
smallfarm
Camera is indoors or out? Outdoors needs to be able to weatherproof the connection like the Arlo outdoor adapter.
smallfarm
thank you!
