Videos not appearing on SD card
  • 5 Replies
  • 323 Views
Red15Baron
Luminary
Luminary
I purchased a new Essential camera, and I’m experiencing an issue with videos not displaying on my SD card. All my other cameras show up on the card. I’ve noticed that on the older cameras, when I view the screens in the device area, there is an SD card icon in the lower right corner, along with battery power and Wi-Fi strength icons. These icons don’t appear on the new camera's screen. Any help with this problem will be appreciated. Keith
Red15Baron
Luminary
Luminary
This problem seems to have fixed itself. I can now see the videos on my SD card.
5 REPLIES 5
Is the camera connected to the smarthub, or is it connected to your home wifi?
Is the camera armed?
Red15Baron
Luminary
Luminary
Since my last post, I have noticed that my videos from the camera are being recorded to the cloud and not to the local SD card. I don't know how to get it to change over. All my other cameras are sending videos to the SD card?
Red15Baron
Luminary
Luminary
Yes Stephen it is connected to the hub and is armed. Thanks for replying to my message.
Is local storage set up in the smarthub?
If you aren't seeing the recordings when you press "local" in the app, then you should try ejecting the SD card from the app and connecting it directly to your PC.  Then look for recordings.
Red15Baron
Luminary
Luminary
