I've been an ARLO user for a number of years - I have five Pro 2 cameras and two Base Stations (VMB3500r4 and VMB4500r2) using a free 7-day storage plan. All cameras are mounted outside with all but one powered by charging cables with the micro-USB connection. I was planning on replacing my driveway camera with the Essential 2K 2nd gen - since it has a USB-C connection, I planned on using a micro-USB to USB-C adapter so I wouldn’t have to do a rewire job. is the Essential 2K 2nd gen camera compatible with either of the Base Stations? Will it's videos be saved for 7 days as my Pro 2 videos are? will the micro-usb to usb-c adapter work ok to keep it charged? Do you know any reason this substitution won't work as I've described?
Two to three major hurdles.
Any camera newer than the pro2 requires a subscription plan to record to the arlo cloud storage service, they are also not compatible with the VMB3000 series base stations.
Any 2nd generation camera or the arlo pro5 Cameras requires the arlo new experience UI app to be loaded that is rated as a failure by the average user. Note: No option to revert back from arlo.
The 2nd generation devices have only recently been made compatible with the arlo base stations excluding the above mentioned 3000 series base so firmware update is required which has been problematic for arlo.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
