- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Re: Suddently start recording constantly also in s...
It has worked fine for months but all of a sudden has started to record constantly hence draining the battery regardless of mode. Have tried to restart but nothing helps.
Have you gone into the Standby mode settings and made sure there is no rule for the camera there?
Yes of course, it does not really matter what rules I have - they all get "overruled" in the way that it records regardless. It records for 11 s and then it stops for30 s or so and then it starts again so I get like five hundred recordings over night.
Then I suggest removing the camera from the account, and then doing a hardware reset. Do that by holding down the pairing button until the camera LED flashed amber (~15 sec). Then add the camera back to your account.
The problem seems now to be solved. But it took approx a week for Verisure to remove the account so that I could remove the camera from the Arlo account. Doing a new installation seems to have done the job. Thanks. I will carefully evaluate this going forward.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
