- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Not recording locally Essential with Base Station
I know this has been covered before on this forum (a number of times). But I have read through most of these posts for two days to try and work this problem out.
I have three Essential Gen 2 Cameras and a Base Station. Initial free subscription has expired. I have a USB fitted to the Base Station. The USB has been formatted using the Arlo App. Under Device>Base Station>Storage Setting>Local Storage, the Storage Status states 'Good'. There is also plenty of space on the USB. Under Devices>Base Station>Storage Setting>Local Storage>, View Recording is toggled to 'On'.
When the system mode is set to 'Armed' I get notifications, but no recording.
I have no ability to select Record when I am viewing any of my Cameras live.
Under Modes>Device Rules>Motion Detected, the Record toggle for each camera is greyed out.
This is expected behavior, as manual recording requires a subscription.
A smarthub only records videos for the cameras connected to it. So no local recordings are made for cameras connected to your home wifi.
Gen 2 cameras can't be connected to a base, as Arlo hasn't released that feature yet. So if you have Gen 2, they must be connected directly to your home wifi.
Let us know if you actually have Gen 1 cameras that are connected to your base.
Definitely Gen 2 Cameras.
The things you miss in the fine print!
I don't recall ever seeing this issue in print when I bought the Base Station. More proof that Arlo business plan is to force people into paying for subscriptions by making things unavailable, or just plain difficult.
Hello!
I have Gen 1 Essential Camera and Doorbells and local recordings stopped working after the Secure app upgrade. I have a VMB4540r3. No subscription service. Help please.
@Aurorus2014 wrote:
Hello!
Did you check the USB storage on a PC?
It'd be useful to know if the issue is with recording or playback.
I have this same issue as everyone else. My cameras do not record locally I don't have gen 2 cameras I don't believe. They recorded when I first got them, of course that was w/ the trial subscription. I have a HD hooked up to the base and it is perfectly fine and there is plenty of room on it. I will get rid of my alro cameras before I will pay for the subscription
First question - are the cameras connected to your base/hub or to your WiFi? They must be connected to the base/hub for local recordings.
2nd q - have you ejected the drive to view it on a computer to see if recordings are there?
3rd q - what base or hub do you have? Only the VMB4540 and 5000 hubs can use the app to view local recordings.
Lastly, it may be the hard drive that's the issue if you're trying to power it from the USB port. An external power supply may be needed. Regardless, a cheap thumb drive holds a lot of recordings and doesn't have issues with the USB port.
Q1- Connected to the base if it was wifi it wouldn't record to the base
Q2- Yes there are no recordings
Q3- VMB4540r2
Q4- It's recongizes the HD and knows it there it's a USB specific HD. I had a flash drive in it and it wasn't recording then either.
I have also confirm the HD is not the problem
Additional q - did you format the drive to FAT32? On a computer, you'll likely need to use a 3rd party program to do so. While connected to the computer, check for multiple partitions and remove them if found, then format to FAT32. Formatting can be easier done on the hub since it only supports FAT32.
Thank you all foe the replies.
Yes - Gen 1 cameras are connected to Arlo Base station (not my normal wifi network)
Recordings were fine up until the Arlo app update
No - I haven’t ejected the usb memory stick. Don’t feel like I need too because recordings to the base station (without a subscription was working)
So I suspect a patch is needed for the new Arlo App.
Do we have any Arlo developers reps here?
I suggest doing it anyway. It will help confirm whether the problem is making recordings or accessing them.
Hello, I found the recordings
Its under Devices, Base Station, Storage Settings.
It’s nested inside all these menus which is not good, rather under the “feed” tab that replaced the “library” not good.
I have no events or recordings under “feed” - is it possible to show the locally stored recordings here?
Unfortunately, no. Personally I think Arlo should add an option to do that.
Not good.
I can access, but my wife’s account (non-primary) cannot access - as far as I can tell.
Anyone know if you can set the second account up so the base station can be accessed under devices?
How do we give feedback back to Arlo?
I’m almost at the point of ripping all my Arlo devices out and going with something else. And I’ve had this system up and running for about just over a year.
If Arlo has to rely on software locking hardware functionality out, so that people move to a monthly subscription service to stay solvent - then I’m tapping out very soon.
You cannot. That is one of several limitations of direct access to local storage
- recordings can only be accessed from the app (not the browser)
- recordings can only be accessed from the primary account (not friend accounts)
- no ability to make manual recordings or take snapshots
- no thumbnails - all videos need to be downloaded to the phone to view
- remote access requires router setting changes that many find difficult (and which don't work with some internet service providers).
Unfortunately, not a good experience (and it has been this way ever since it was launched)
I also have two essential first gen cameras which were recording locally and access via app fine to the base station VMB 4540 well after their 3month trial cloud period.
In May after software upgrade they no longer motion record. USB has a lot of spare space, I ejected no recordings on pc. Very frustrating. Have reset up from scratch no changes.
Same issue here. Local recordings not working after app update (around May?)
When will the update be released for essential XL gen 2 to allow for local storage on the smart hub?
2nd generation devices can now connect to compatible Base Stations and SmartHubs to allow local storage. You can read more about this here: https://community.arlo.com/t5/Announcements/Essential-2nd-Generation-devices-are-now-compatible-with...
Thanks James, thats great news. I now have it connected to my base station and confirm its recording. Well done!
Query, is this also meant to include Homekit Integration?
Video is still not feeding to my phone/TV’s Home App. I can see for gen 1 and door bell but not these ones.
Unfortunately, not yet.
Thanks. Are there any plans to integrate with iOS HomeKit?
I would like this please.
Aurorus2014,
Base Station support is the first piece needed to allow for Apple Home integration. Now that the firmware allowing Base Station integration is complete, we're working on getting Apple Home certification for gen 2 devices. Once this is complete, we'll make an announcement here on the community.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
