- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Network name entered incorrectly when it is correc...
Network name entered incorrectly when it is correct?
I have yet another issue with my arlo camera. Because of my previous issues with getting the camera to do basic things like recording motion, I decided to re-pair the device.
I can now no longer connect to my network even though the ssid is correct and it's only broadcasting 2.4ghz.
I'm using a Deco router. Also, why can't I get access to live support? I'm a paying customer but arlo won't let me access help support?
Try and reset the camera and try again. If you switch on location services on your phone then Arlo app will automatically find the SSID for you and all you have to do is enter the password correctly. Make sure that your phone is on the same wifi network as the one you're trying to connect the camera to.
Thanks for your reply. I ended up finding an option in the Deco app that created a network especially for iot devices. It was then able to connect to that network.
Hopefully this information is helpful to anyone else having issues with Deco and Arlo.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
