- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Re: My Essential Gen 2 won't pair with my VMB5000 ...
I've tried resetting the hub, all the cameras and I can only get my Arlo Pro cameras to pair, but my Essential Gen 2 outdoor cameras will not pair
Will they connect to WiFi? That may be needed to get updated firmware that will then allow the cameras to connect to the hub (you'll have to remove them from your account and onboard them again to do that).
It connected and immediately did a firmware update. The camera shows up on my feed, it just won't pair with the hub so I can record locally.
And when the update was complete, did you remove the camera from your account and try to add it to the hub? The setup procedure should show you a choice of hub vs. WiFi although, IIRC, you may have to connect to WiFi and then the procedure allows you to connect to the hub (I may have this mixed up - it's been a while).
I'll give that a try, thanks!
I removed it from the hub and my app and it still won't show that it's paired with the hub. My other 2 Ultra cameras showed "paired" when you click on the hub. Soooo frustrating!!
You say you removed it but did you then connect it again?
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
