The mount have this little cog design and when it is mounted on the camera its is not straight. To get the cam straight, I need to only use one screw on the wall mount and then turn the camera so it’s straight. Anyone seen this ?
Can't you just loosen the center screw, rotate the camera to straighten it, and then tighten the center screw again?
At 1:57 in the video she is turning the ring on the mount. That can not be done with the mount to this camera.
It is completely rigid once it has been fastened.
Its the same on both mounts that came with the two cameras.
Due to the cogs that it has to clicked into, it can not be put straight. The cogs are somehow not made to keep it straight ....
@Orrefors I think I now what the concern is. You can rotate the camera once it's mounted and screwed in, You may not have noticed because it requires some force to turn the camera physically. If you provide a little forceful turning in any direction, it should move on the balls pivot point.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
