Introducing the 2nd generation of the Essential camera, now offered in both 2K and HD options. Experience exceptional smart home security with unbeatable value and price. We all deserve protection, no matter what your budget is or the size of your property. Choose from 2K or HD camera options for round-the-clock protection.
Essential Coverage. Everyday Protection. Essential Outdoor Camera provides smart home security with clear HD 1080P resolution, Color HD Night Vision, and Integrated Siren. Check-in on your home, family or pets anytime.
·        First sub $50 HD security camera
·        Updated seamless Bluetooth onboarding
·        130° field of view
·        Wire-free with built-in rechargeable battery for long lasting battery life
·        Integrated Spotlight
·        Color Night Vision
·        Sleeker form factor with newer battery technology
Essential Coverage. Crystal-Clear Details. Essential Outdoor Camera provides enhanced smart home security with crystal clear 2K resolution and zoom in to see more details without distortion day or night with Color Night Vision.
·        First sub $100 2K security camera
Post a reply or visit Arlo Support if you have any additional questions or need more information about the Arlo Essential Outdoor Camera - 2nd Generation.
Thank you for being part of the Arlo Community!
190 REPLIES 190
kb9hgi
This thing still will not connect to my hub. It updated the firmware when I chose to connect to hub then it searching for device in our system but then it says Camera failed to connect Error Code 65535. I'm about fed up with it!
kb9hgi
I have a VMB4000 Base station and trying to add the Arlo Essential Outdoor Camera HD 2nd Generation. It updated the firmware but still will not connect to that camera to the VMB4000. I have tried several times and no go.
b4better
It works for me. Thanks Arlo firmware team and James.
As earlier it requires a subscription to save videos, I have put the camera on a resell website with heavily discounted price, and I wasn't able to sell. Now I took it off from the website. With this feature, there probably will be more buyers reaching out to me, but I'd rather keep the working camera.
Tjhastings
Where do I find the connect to hub option
ive removed one camera, it’s on the most recent firmware as described . I’ve re added and I can’t find any hub option
kb9hgi
How did you get the camera to work on the Base station?
kb9hgi
Mine keeps saying Camera failed to connect Error code 65535 and I have the new firmware update. This thing is still junk!
kb9hgi,
To get the latest firmware that allows the base station compatibility you first need to onboard your Essential 2 device directly to your home network to complete the firmware update. Have you done this?
After the firmware updates, you can then remove the device and onboard again selecting the base station option during the onboarding flow.
CoopersPC
yes i had 2 cameras connected, and 2 that never was. the 2 connected, were already up-to-date firmware.. just had to remove and re-add connecting to the hub the other 2 that never connected , i did have to connect to let them update the firmware.. then disconnect and reconnect to the hub. I did have some odd issues with the finishing, but they all connected and showed the hub on the 2nd connection
kb9hgi
Yes I had it on my wifi and it did the upgrade for the firmware. I then removed it from the wifi and I go thru setup again. It finds my camera then I pick hob/base station and it finds my vmb4000 base station but the camera will not connect to it.
gIr0d
@JamesC  thanks for letting us know that the Doorbell 2nd Gen is now capable to connect to the SmartHub, it works nicely. However, do you know how or by when Arlo is considering that the local recordings appear also in the "feed" tab please? As for now its quite uncomfortable to see the recordings via devices --> Smarthub --> storage settings... 😞
Tjhastings
Is there a firmware update intended to connect the camera to HomeKit either via wifi or the hub
Tjhastings,
Apple Home integration will follow this update. Once Home integration is available, we'll post another announcement here on the community.
Tjhastings
Any approximate timeline ?
gIr0d
@JamesC  can this be implemented/allowed please in the app? It is providing the notification but not in the feeds, I think its more a "where you show the recordings" question in the App rather than a technical limitation.
See my post before: thanks for letting us know that the Doorbell 2nd Gen is now capable to connect to the SmartHub, it works nicely. However, do you know how or by when Arlo is considering that the local recordings appear also in the "feed" tab please? As for now its quite uncomfortable to see the recordings via devices --> Smarthub --> storage settings... 😞
DaceWills
@DDD Thank you for the update! I'll keep an eye out for any announcements on the community and Arlo website.
Dharmon
I am getting really depressed tying to talk to a live person but I keep getting the runaround for 2 hours I been trying.  What the big Dell
Ask your question(s) here - on a new discussion thread.
Victoriamont
When is going to be available in the app to use them in Uruguay (Latin America) ?
iris-chen
cool
Dvano
Hallo ich habe diese Camera. Hat gut functioniert. Habe jetzt dat sonnepaneel und.... drama. Der camera lief leer und disconected und was ich mage er ladet nicht meer und connect nicht meer. Bitte was zu tun? Verisure helft mir nicht und habe diese camera nur 6 monaten!!!
Es blinkt ab und zu eine rote lampe aber es gelinkt nicht um es blauw zu bekommen!!
Bitte kunnen Sie mir helfen?
Vielen dank
Liebe Grusse Dymph van Ommen
Tjhastings
Any update on timeline for HomeKit patch ?
TatePams
I am having issues adding this model to the APP. Seem like the model is not on the APP yet
It's not available in all countries.  Are you in a country where Arlo offers subscriptions?
MarcoPoncz
Dear,
I read in other post that now is possible to use Base station and SmartHub in connection with Arlo Essential Outdoor 2nd generation. Is this real? Sorry, but I am really begginer in this subject. So I have basic questions?
1. How many cameras I can add in a same Base Station/SmartHub?
  • 2. Using a Base Station or SmartHub, it’s possible to storage videos in the cloud or in external device (memory card, pen drive,…..) ?
1) You can add as many cameras to a base or hub as you desire. At some point (15 has been suggested before) the base/hub hardware may not be able to properly handle all of them. I think I have 12 or 13 connected to my hub.
2) With a subscription, you can get cloud recordings regardless of having a base or hub. However, by connecting the camera(s) to a hub you can also get local recordings as either a backup or instead of cloud recordings (not the same experience as with cloud recordings so compare before canceling any subscription).
