- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Essential XL outdoor cameras not connecting to liv...
I have two 2nd gen Essential XL outdoor cameras. For the past few weeks it’s not possible to connect to live feed. I have other Arlo cameras of different types, all working fine. It’s just these two.
It looks like they’re online but you can’t connect to live feed. I’ve tried restarting them, removing & re-adding and factory reset. This fixes the problem for a few minutes, then the same problem occurs.
I’ve contacted Arlo and they weren’t able to help. It seems this problem is since the latest firmware update.
Had anyone had a similar problem or know how to fix it?
One more thing to try - reboot your router. Otherwise, use the app to go to Settings, Support and choose a method to see what official support may offer.
If you bring one of the cameras closer to your router does live view then work?
No, sadly not. The signal strength is good. I brought the both in the house near the router and still had the same problem.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
