We have 3 Arlo 4 cameras and just got 2 more of the Essential Outdoor Generation 2 from Amazon Prime Day. The other ones have great mounts - you can rotate the camera to the exact way you want and these are immobile once mounted? You can't rotate them at all. Am I missing something? The other ones are great with the magnetic mount.
You can rotate the Gen 2 cameras - though the mount is stiff, so it does take more force.
Note you can also use third-party mounts, using any mount with the standard 1/4-20 UNC threads.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
