  • 1 Reply
  • 316 Views
Queenie27
We have 3 Arlo 4 cameras and just got 2 more of the Essential Outdoor Generation 2 from Amazon Prime Day.  The other ones have great mounts - you can rotate the camera to the exact way you want and these are immobile once mounted?  You can't rotate them at all.   Am I missing something?  The other ones are great with the magnetic mount.
You can rotate the Gen 2 cameras - though the mount is stiff, so it does take more force.
Note you can also use third-party mounts, using any mount with the standard 1/4-20 UNC threads.
