- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Essential 2nd generation washed out image/shades o...
Got my new Essential camera connected today but the video or picture has be terrible color and image quality. It is basically just shades of pink and looks washed out? WiFi connection is great.
The firmware version resolving this issue was released to your cameras overnight. Please test again and let us know if you're still experiencing this issue.
I wonder if the camera brightness control is set too high. Look in the camera video settings, should be 0 or +1 for best picture.
Kipper5,
The development team is currently investigating reports of this issue and will be releasing a firmware update to address these concerns.
I will provide more information once this firmware update is available.
I read there was firmware released to correct this. It has not corrected mine.
please advise.
thank you
Mglea,
The issue being discussed here is relevant to Essential 2nd generation outdoor cameras, you appear to have a Pro 4 camera. Can you verify the model number for your device and are you able to provide a screenshot of what you're seeing?
I am having the same problem with 2 of my cameras. They say a fix has been released. How do I get that ?
Do the cameras get updated automatically or is there something I need to do ?
Kantup5,
The cameras will update automatically. I've taken a look a the devices you have associated with your account and you do not appear to have any Essential 2nd Generation devices, so the fix mentioned here may not apply. What model are the devices you have that are experiencing the issue?
1.080.20.1_23_d50a19d
H4
AA38227FA138C
Kantup5,
That s/n is associated with an Arlo Pro 4 camera. I encourage you to remove and reinsert the battery for that device, allow it to come back online and test again to see if you experience the same behavior. If you still have the same issue, I recommend reaching out to the Arlo Support team using the Arlo app under Settings > Support to open a ticket and further investigate the issue.
I contacted support after replacing the battery with no improvement. Dealing with support is a very painful process. My cameras are remote and they want me to give them the serial number which they should have access to, Then he wanted a video, then he advised taking the battery out, then advised to reset remove and ad the camera back in. One camera is in Michigan where it's 20 degrees and another is in the Virgin Islands. Pretty difficult to reset and resync cameras especially if support knows the problem will not be resolved after the dog n pony show. Very frustrating !!
180 degree
Android App
animal
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Battery life
Essential Camera feature request
Essential outdoor
Google Nest
Idk
need help
New features
Night vision
Payment
privacy zones essential 2k
problemshooting
Record
smart things
Unknown charges
VMC3050
