  • 2 Replies
  • 373 Views
dnierle
I am following up on case #44035936, which you have closed. I followed all your instructions and the camera then worked well for about a week. Then the battery charge fell from approximately 86% to 56% in about 2 hours with only 4 - 15 second videos. Then there were about 40 -15 second videos in about an hour and the charge only fell about 3%. There seems to be something wrong with this battery and/or solar charging. Please advise. Thank you,
Why, pray tell, are you posting personal info on the internet?
If you disconnect the solar panels does the battery then last normally?
dnierle,
If you're still experiencing an issue after the troubleshooting provided in the case notes, I recommend you open another ticket and request an RMA as you could be experiencing a hardware issue. You can open a support ticket using the Arlo app under settings > support.
