Can this camera be set up to use WiFi?
I have arlo smart hub for my home security.. Can I use an arlo essential wire free camera in my motorhome with WiFi connection?
Is the motor home in range of the home/local wifi or is for when you go away?
when you say you have a smart hub for home security, do you mean a base/hub or the arlo home security system with a keypad?
I don’t believe the essential gen2 is compatible with a base/hub only wifi.
The 2nd Gen cameras can only be connected to your WiFi. Arlo is planning to add smarthub support, but haven't said when.
Adding the camera will migrate your account to "Feed", so if you see "Library" in your app menu, then you should search this forum to learn about "Feed" before you purchase. Also, 2nd Gen cameras aren't supported in all regions, so you should also check on that.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
