Can't Connect Camera
I currently have two Arlo cameras: Essential Outdoor 2nd gen & doorbell. I purchased an indoor Essential camera being sold on eBay as a 2nd gen. It arrived today, and the pairing button is on the bottom so that means it's not a 2nd gen, correct? I can't connect it to my network. It must be because it's not 2.4 GHz. Besides trying to return the camera, what are my options? Thanks.
The camera is definitely 2.4 ghz. If you are saying your network doesn't have a 2.4 ghz band, then you likely are wrong about that. Almost all 5 ghz routers are actually dual band (supporting both). Are you able to log into the router's web page, and check?
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
