Cameras unable to reboot
  • 1684 Views
jetliner
After power outages, three cameras are not coming back on line. Using the Arlo secure app doesn’t seem to be connecting to the WiFi.
ZeliardM
I'm also having this issue. I have one camera that will reboot when I select restart, but two others that will not. I've restarted my wireless network, I can't get the cameras to respond through the app or web portal at all, no live stream either.
jetliner
Just figured it out, when I hit “add device “ went thru the steps till it says choose wifi. Mine said “use saved WiFi “, choose different WiFi, tap the same WiFi it then ask for password. This was the WiFi I always use, I was just logged out after the power outage.
ZeliardM
Glad that worked out, I may need to just reconnect mine as well. Will give that a shot. Thanks!
