Cameras are not recording or showing in feed?
  • 1 Reply
  • 659 Views
Gunnar12
Last week I installed 8 Essential Outdoor 2nd Generation cameras. The installation process was easy I had zero problems and they all worked fine. This was on Friday. Then this week, I've noticed my cameras are not picking up anything or showing anything in the feed since Friday. Even though they are on, connected to Wifi, and the Live Feed works. I don't know what to do with this. I have the Arlo Secure app and use it on my phone and its not working.
Check the active mode at the top in the Dashboard - it may be that you inadvertently set a different mode. Arm Away should always work if you haven't made changes to it in Routines. The other modes require that you add rules for the cameras you need when using that mode. Here's an FAQ that may help:
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
