Camera battery draining too fast
Hello, this is my second time with this same issue. This time with a different camera. I charge the camera, and the battery drains quickly even with no activity. Based on last experience I tested the battery by fully charging it and then facing the camera toward a wall for 24 hours. The camera lost 5% of the battery doing nothing in that 24 hours. Please advise if you have any other tips?
Battery life
A signal strength/quality issue could be causing this. I assume when you faced the camera towards a wall you brought the camera closer to your router - is that correct? Are there any other wireless devices that also use the 2.4GHz band near the router or the camera? Do you have other cameras that would allow you to swap them around to see if the location is the issue?
Hello,
The camera is still facing the wall, and it lost another 5% in 24 hrs. It is inside now, about 25 feet from my wireless beacon (yes, my guest network has got a 2.4 gh band to it). I can put it where my one other outdoor camera is, which gets much more activity than it's usual location behind my house, and see how fast it drains. I'll report back tomorrow.
Thank you,
Wendy
Hello, I moved the camera whose battery was draining too fast to a different location, swapping it with another camera. It is still losing 5% of battery life per day.
Any ideas?
Use the app to go to Settings, Support and choose your camera. Scroll down to Contacts to see what official support offers. It sounds like a faulty camera to me.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
