I’m using a VMB4000 base with both 1st &2nd generation essentials cameras. I’m getting notifications of motions but there are no recordings. I connected a flash drive thinking that would help. But nothing
Do you have a subscription?
Note that the VMB4000 supports local recording, but not playback. The only way to see the local recordings is to eject the storage from the app, and connect it to a PC. Have you tried that?
No subscription. Before I was able to play back for up to a week. I have had the Arlo Base Station for years with no problems. Then I decided to purchase Gen 2 cameras and merge them with the base station and now no recording or playback. Also the Gen 2 camera will not show any recording on flash drive
Is the Gen 2 camera connected to your home wifi or is it connected to the VMB4000?
Do you now have more than 5 unsubscribed cameras in the account? If you are over that limit, then you lose the free 7-day cloud storage for your legacy cameras.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
