Automation not following Scheduled time to change
  • 4 Replies
  • 1633 Views
Agostino
Bonjour,
depuis l'installation de 2 cameras Arlo Essential 2K , j'ai du faire un update de l'application, après avoir je ne vous cache pas galérer a faire le paramétrage de celle-ci, j'ai problème avec la mise en service.
Mon paramétrage indique une mis en servie à 23h00 et tous les soirs le hub active toute les cameras à 23h05
Matériel VMB5000r4 firmware 1.24.0.1_1607_8938370
"Hello,
Since the installation of 2 Arlo Essential 2K cameras, I had to do an update of the application, after having I do not hide you struggling to make the configuration of it, I have a problem with the commissioning.
My setting indicates a service at 11:00 p.m. and every evening the hub activates all the cameras at 11:05 p.m.
Hardware VMB5000r4 firmware 1.24.0.1_1607_8938370"
ShayneS
@Agostino
Thanks for the feedback. I will look in to this and provide more info as soon as possible.
Essential 2K cameras can't be connected to your smarthub.
Are all the cameras being armed at the same time (11:05 pm)?
I have a somewhat similar issue but I assumed it was caused by use of an Arlo Home Security System. Before I had the security system set up, the schedule worked flawlessly. Now the nighttime switch of modes to Arm Away varies from the desired 11:00PM to 11:05PM. This post sounds like it's not the security system per se that's causing the issue but firmware/backend software that the new user interface which uses Feed has introduced.
@ShayneS would you please add this to the problem description?
ShayneS
Hi @Agostino
The symptoms you were experiencing with the scheduling changes should now be resolved. Can you reboot your base station and check again.
