Arlo Essential 2K (2nd Gen) - Is there a specific separate mount i need to buy?
  • 1 Reply
  • 1696 Views
vdaam
Looking at purchasing 2xArlo Essential 2K cameras (2nd generation) however doing my homework first.
Am wanting to mount them to the soffit of my home however they only come with wall mounts. Is there a specific separate mount i need to buy for them to secure them to the soffit? I've been trying to look online however can't find any solution.
In the past have had the original essential cameras with the ball mounts (which worked great) but seemed to have changed with this new gen.
I'm based in NZ so unfortunately aren't blessed with Amazon etc. so i don't have many options
Appreciate any advice!
The cameras have a standard 1/4"-20 thread that's used by almost every camera maker. Check whatever stores you have access to for outside camera mounts that will suit your needs.
