Looking at purchasing 2xArlo Essential 2K cameras (2nd generation) however doing my homework first.
Am wanting to mount them to the soffit of my home however they only come with wall mounts. Is there a specific separate mount i need to buy for them to secure them to the soffit? I've been trying to look online however can't find any solution.
In the past have had the original essential cameras with the ball mounts (which worked great) but seemed to have changed with this new gen.
I'm based in NZ so unfortunately aren't blessed with Amazon etc. so i don't have many options
Appreciate any advice!
The cameras have a standard 1/4"-20 thread that's used by almost every camera maker. Check whatever stores you have access to for outside camera mounts that will suit your needs.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
