Has anyone had a successful refund through Arlo?
I have brought a second camera after having one for over a year working fine and loving it.
My new camera took me days with support and consistency to connect (it kept saying looking for camera and failing) eventually I got it to connect then it wouldn’t load a picture. This took a day or two to load, since then I have only been able to load the picture a handful of times over the last week. I have been in my yard and received only about 3 notifications when there has been consistent movement. Now the newest problem is the camera now has 13% battery after only been fully charge not even a week ago.
I don’t have the original box I purchased it with so can’t return in store, however I believe Arlo should help assist with a refund or replacement. But yet I have requested and they keep giving me options to try which aren’t helping the situation. It definitely isn’t the wifi connection as my other camera is in the same spot facing the other direction working fine.
Has anyone been successful in getting problems resolved?
ps should add I have the essential wire free camera.
Arlo recommendation is for cameras not to be located closer than 10ft to another camera. This could be causing the camera to loose wifi connection intermittently and drain battery. Separate cameras to prove.
I have escalated your case & someone from support will be reaching out to you as soon as possible. I have provided your escalations number here: 43400057
Ive tried to ask for a refund for the account I closed about 2 weeks ago. I just keep getting suggestions to solve everything but my refund.
I sold the cam gear about 1 yr ago. Arlo charged me for a yr sub $119.88. I cancelled my account. I havent a phone number to talk to anyone about it. All the links after asking a question just leads me in a circle asking if the answer helped etc etc then give me more selections to choose from. This shouldnt be difficult. When will Arlo send me my money back?
Arlo does not provide any pro rated refunds. You can find more info here under the terms and conditions 11.4 Refund policy: https://www.arlo.com/en-us/terms-and-conditions.html
2 days after my auto renew of sub and cancel due to not having the cams and gear. It is arlos policy not to refund that is info That I will share on the many reviews everywhere I can and also share what about the gear and the problems with it. Arlos support is limited using robots to try to answer problems . The BBB will be my next contact about this company.
Hi @vray50
Your subscription is still active at the moment until the end of your billing cycle. I reviewed your account and I can have my team refund you since the cancelation occurred a few days after the renewal. Once the refund is processed it will end the active subscription as well.
Please let me know if you would like to proceed.
Thank you
Yes Sir please proceed.
Hi @vray50 Sorry for the late reply, I was able to have my team issue a refund. This process was completed today. Please note, the refund process should make take within 3-5 business days, this may depend on your financial institution as well.
Thank you
Hello I wanted to contact you about the refund. It showed up on my bank account . Thank you Sir. I appreciate your help with this matter.
Awesome, Thank you for allowing me the opportunity to resolve this for you. Let me know if you need anything else.
Arlo Essential
Arlo Video Doorbell
