SolarPanel & Kabel für Essential XL
Hallo liebe Community
könnt ihr mir bitte sagen, welches Solarpanel und welches Kabel. ich bestellen muss, um meine Essential XL ohne Akku, resp. Strom zu betreiben. (Ich möchte sie draussen, geschützt vor Wind und Wetter unter einem Glasdach betreiben)
Vielen Dank & Gruss aus der Schweiz
Fish68
All Essential outdoor cameras are fully sealed, and have a battery inside. That battery cannot be removed.
Note the outdoor camera will not detect motion through glass. It uses a passive infrared (PIR) sensor, and most window glass blocks the IR.
@Fish68 wrote:könnt ihr mir bitte sagen, welches Solarpanel und welches Kabel.
Do you have the original Essential XL? Or do you have the Gen 2 camera? They use different panels.
The original XL has a microUSB connector for charging. The Gen 2 has a USB-C connector.
Thanks for your reply. My Essential has a microUSB connector and Serial-No. A7G20B7FA0984. It is a original Arlo Essential XL and I would like to operate it with a Solarpanel. To do so I need to know which one I have to order incl. the connection cable, as I cannot see that anywhere... Thank you. 🙂
The Arlo panel is the VMA3600. There is no need for a separate cable.
It is currently out of stock in the Arlo US store. I don't work for Arlo, so I have no idea when or if it will be back in stock. There are some third-party panels that claim to be compatible.
Arlo Essential
Arlo Video Doorbell
