Missing yellow RJ45 port on VMB3000 base station. Someone pulled it out when disconnecting unit
  • 1 Reply
  • 1703 Views
JWC49
Is it possible to buy a yellow ethernet RJ45 port to snap back into the base station?  I can see the 8 wire prongs at the bottom of the square hole, but an ethernet cable can't click into anything without the yellow port piece.
Arlo doesn't sell parts, and doesn't repair base stations or cameras.
You can find replacement RJ45 ports (no need to match the color of course).  But you might need to find a local electronics shop to install it for you.  They might already have the part, so I'd start with finding the shop.
  • 1 Reply
  • 1704 Views
