I've found where ARLO states that they recommend a MINIMUM 16GB SD card, but I can't find where they recommend a MAXIMUM. Is there a limit on the size of SD card the Smart hub will accept?
I finally went with a 256GB card. Thank you.
I've seen posts from people who've successfully used 512 GB, but haven't seen anyone reporting success with anything larger.
Personally I find 128 GB to be more than enough.
Arlo Essential
Arlo Video Doorbell
