  • 1 Reply
  • 731 Views
DRog
I use four essential indoor cameras. When in geofencing mode, only the large radius seems work. Medium and small radiuses do not disarm when I am home. My preference would be to apply the small radius. Any suggestions on how best to optimize? I use a Note 10+ Android 11. Cameras are new. Thanks
DRog,
Are you experiencing intermittent behavior with the small or medium options or do they never work correctly? If the large setting is working consistently, I encourage you to continuing using it over small and medium. Geofencing precision may vary depending on the geography, which is why these different options are available.
  • 1 Reply
  • 732 Views
