Essential club instructions
  • 6 Replies
  • 3247 Views
Thredbolodge
I just bought an Arlo essentials class and the downloaded instructions on how to use and setup the camera are nothing like the actual camera options you get with a new camera, it would be nice if new instructions were written for newer updated cameras
6 REPLIES 6
DannyBearAgain
What specific instructions are you looking for?
Arlo has recently updated to a new UI interface so the older instructions will be for the older UI interface.
Thredbolodge
It say to :
Change the camera order
1. Open the Arlo app.
2. Tap Settings.
3. Under DEVICE SETTINGS, tap Device Order.
4. If you are using a smartphone or tablet, tap Edit at the top of the page.
A list icon displays.
5. Tap and hold the e list icon and drag each device to the correct position on the list.
6. Tap Save.
I dont get this option at all for starters, and I also dont get many other options listed in the instructions.
Thredbolodge
"Device order" is not an option on the latest Essentials XL camera, so very frustrating when trying to follow these instructions.
DannyBearAgain
Refer to the new UI interface in article.
https://kb.arlo.com/1088401/How-to-add-an-additional-Arlo-device-to-an-existing-Arlo-system
it's not the exact process but might workaround the missing features.
Thredbolodge
I have spent 2 whole days on this and about 15 hours in total, I am going to get a refund and buy a Eufy
DannyBearAgain
You can contact arlo customer support if you’re have a trial subscription when you purchased the camera.
in the arlo mobile app under settings select support and choose the camera for a list of contact entitlements.
  • 6 Replies
  • 3248 Views
