  • 5537 Views
Jimbuck
Had no problem with a couple Pro 4’s but I cannot get the indoor Essential camera to read the provided symbol to join connect with WIFI.  Every time the camera blinks blue for only 6 seconds and the privacy door closes after 10 seconds - No chime.  Have tried numerous times and repeatedly followed Arlo’ suggestions
Jimbuck
Issue resolved.  Total user error on my part.  Although I never did get a factory reset performed (never got that amber flashing light) I did get the camera to accept the QR code and progress normally.  Turns out I was holding the sync button too long (holding it until the camera began flashing blue).  With a quick touch, several seconds later it began its blue flashing and took the code straight away with a reassuring chime.
First try the factory reset (holding down on sync until it flashes orange).
Then maybe try using a PC (browsing to my.arlo.com) instead of the app.  Also be very careful when entering the network name and password - both are case sensitive.
Also be careful to select the correct camera model when adding the indoor camera.
Jimbuck
I cannot get it to factory reset.  Held the sync button for two minutes And it only continued to blink blue while I held the button.  I did try from the website but the camera still does the same thing.  It only blinks blue for 6 seconds and the privacy door closes after 10 seconds
Jimbuck
  • 5538 Views
