Arlo and indoor camera without using a subscription
  • 1 Reply
  • 2672 Views
Sfc
Arlo essential indoor camera work without a base station and how do I record without using a subscription
If you have no base, then you need a subscription for recordings.  The single-camera Arlo Secure would be sufficient.
If you get a base, you can save recordings locally.  However, if you want to see those recordings in the app, you need a smarthub (VMB4540 or VMB5000).
There are limitations to local storage:
  • Recordings are only available in the app (not the browser)
  • Recordings only available to the primary account (not friend accounts)
  • No ability to make manual recordings and snapshots.
  • No thumbnails
  • Remote access requires router settings changes which some find difficult - and which cannot be made on some networks (for instance StarLink and T-mobile broadband).
Given the cost of the smarthub combined with the limitations, IMO the single camera subscription is the best option.
  • No thumbnails
  • 1 Reply
  • 2673 Views
