- English
- Cameras
- Arlo Essential Indoor 2nd Gen
- replaced my old camera with essential 2nd generati...
replaced my old camera with essential 2nd generation.
I replaced my old camera with essential 2nd generation.
This camera was working very bad since I got it, recently there was a big activity in the room during 4 hours during the day, it didn’t make not a single recording.
I have 7 days archive in arlo app. Today I have received the message that my trial plan is over. First of all, I didn’t get any trial plans, II just replaced old cam with newer one. If new one automatically comes with some plan, I didn’t know that and I would not buy it then. I don’t need 30 days saving on cloud, I need the camera mostly for live. Today it doesn’t work for live at all (I guess because this trial is over)
Any way as i mentioned, camera worked bad since I bought it. Night vision is terrible even though I have night lamp in that room
So what should I do now? I don’t need camera with any regular payment cause I don’t need to storage the data more than a week, as it used to be since I use Arlo from 2019.
if there is no more option to have arlo cam without subscription, I want to return it. It’s useless
Please help.
The trial is automatic, to get you started. After that you need a paid plan for cloud recordings. And camera newer than the Pro 2 requires a paid plan which has been true since 2018.
Any camera connected to an appropriate base or hub can record locally instead of needing a subscription (a SmartHub is suggested since the app can directly access the videos without needing to remove the drive for viewing on a computer). It's not the same presentation as with cloud recordings but some folks are using it to get around the subscription cost. I'd suggest you try it out before making further plans.
Arlo Cameras
audio
battery
Cable
Cord
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
