- English
- Cameras
- Arlo Essential Indoor 2nd Gen
- Base Station VMD 4000 Connection with updated app
Hi there, we have an Arlo Base Station VMD 4000 wiht two cameras that has worked fine for several years. I added two Arlo Essential 2K Outdoor Security cameras (2nd gen) to our system which required the mobile app to update. These camera connect to the app without using the base station and are working well. Now, I cannot connect my Base Station VMD 4000 to the app. When I try, I receive an error that it can't be discovered. I have tried with the app over wifi, ensuring that my wifi was 2.4 ghz. I have tried through a web browser with my computer connected to the same router with an etherlink cable. The base stations light are all green and I have completed the factory reset multiple times. Is there anything else I have try? From arlo's support, I thought I could connect both Essential 2K Outdoor cameras and the base station, but maybe that isn't possible?
Did you set up a new account for the Gen 2 cameras?
If not, did you remove the old cameras and base from the account before installing the Gen 2s?
Arlo Cameras
audio
battery
Cable
Cord
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
