Looking at purchasing 2xArlo Essential 2K cameras (2nd generation) however doing my homework first.
Am wanting to mount them to the soffit of my home however they only come with wall mounts. Is there a specific separate mount i need to buy for them to secure them to the soffit? I've been trying to look online however can't find any solution.
In the past have had the original essential cameras with the ball mounts (which worked great) but seemed to have changed with this new gen.
I'm based in NZ so unfortunately aren't blessed with Amazon etc. so i don't have many options
Appreciate any advice!
Virtually any camera mount that uses the standard 1/4"-20 thread will work. I don't know what sort of stores you have available but these should be in ready supply in many electronics/camera store.
Arlo Cameras
audio
battery
Cable
Cord
Essential Indoor 2nd Gen
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
