AUDIO SUDDENLY STOPPED WORKING
for some reason my audio all of a sudden has stopped recording when I get motion videos, even if it’s set off by “audio”, when I playback the videos, there is no audio. There was always audio before, and is still enabled in all the settings, so I can’t figure out why all of a sudden there is no no audio at all, it’s not a blocking of the microphone, because I checked that and because there would be the background white noise that goes along with audio even if no one is speaking, and there isn’t any white noise, so it’s definitely a technical issue with the camera and not a physical one… if anyone could shed some light that would great
Miajam,
If you play back video using a different device do you still experience the same behavior?
You might try removing the camera, factory resetting and then re-syncing the camera as if it were new and then testing again to see if you still experience the same behavior. See here: https://kb.arlo.com/000062560/How-do-I-factory-reset-my-Arlo-Essential-Indoor-Camera#:~:text=To%20Fa...
Same problem, mine works rarely so seems to be a software not a hardware issue. I've tried everything you suggested
Arlo Cameras
audio
battery
Cable
Cord
Essential Indoor 2nd Gen
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
