I just purchased an Arlo essential spotlight camera and the batter died after a couple days. I was able recharge it once and connect it to a solar charger but it died again after a couple days and now it doesn’t seem to be charging at all..
Justin47,
When you plug in the camera, does the charging icon change in the mobile app indicating it is receiving a charge?
I am having the same problem. The camera won't charge and the light is not showing charging.
ShonaTnReal,
Are you using the charging cable that was originally included with your Arlo kit?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
