- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Essential-2-QA-2023-11-02
- Are there any settings for new App to improve stab...
Are there any settings for new App to improve stability on an Android device?
- Mark Question as New
- Mark Question as Read
2nd Gen Essential camera operation is not stable on my Android phone. Long connection time for live picture and often fails to connect. Image and sound disruption after connection also. Are there camera, phone, or router settings that should be in place to make the operation more stable?
The symptoms you're experiencing could be related to poor camera connectivity or some type of interference at the cameras location.
Try bringing the camera close to your router, temporarily as a test, and initiate a live stream. If this alleviates the issue, it could be that the cameras location is causing a problem.
If you're still experiencing an issue, I encourage you to reach out to the Arlo support team to further investigate the issue. You can find support contact information within the Arlo app under Settings > Support.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
