  • 4 Replies
  • 13141 Views
smj
Hello,
In the manual, it shows a power switch.  I do not see that on my unit. My camera came with the Rabbit Feet attached.  I'm going to guess that they have to be removed.How do I do this (manual does not specify)?  Also, do the feet have to be removed if I want to use the wall mount that came with the unit?
Thnaks,
Scott
tunguyen
Hi Scott,
Holding the camera with the front facing you in one hand, use the other hand and twist the feet base anti-clockwise. You may need to use a bit of force, but it should come off.
Thanks,
Tu
tunguyen
Hi Scott,
Thanks,
Tu
smj
Thanks Tu.  I'll give it a shot when I get home.  Wasn't sure if I was supposed to Twist/turn or pull.
Took me a while to get it, too. Quite tight so carefully apply force when removing and replacing. Feel the click.
smj
Thanks for the input.  I was able to get the feet off with no problems.
  • 4 Replies
  • 13142 Views
