Strange thing captured with night vision - Arlo Baby
  • 1 Reply
  • 1127 Views
r4nd0m
Hi guys,
I use an Arlo Baby in our sons room and it triggered motion earlier so I had a look - couldnt believe my eyes what I saw - had a look at the community but couldnt find any similar post.
Setup: Arlo Baby - room has 22C, no heating, no window openend and the door (left of the view) is slightly opened probably 5cm.
Can someone explain what this is? https://my.arlo.com/hmsweb/users/library/share/link/8AFABAF5F119490D_201908
I did analyse it a bit and you can clearly see if comes through the grill, hides partially the bars, slightly dips before changing direction upwards.
Interested in any explaination.
cheers
r4n
It's a particle of dust floating in room.... the IR lights hit it and it glows white
( baby cam puts out a small amount of heat)
Think of a sun beam and seeing particles floating in same
See it all the time in my garage where there is a bit more dust.
  • 1 Reply
  • 1128 Views
