  • 5806 Views
CircusAnimals
Ants have got into the camera - I’m from Australia, it could be worse - and I need to open it up to clean them out.
There are no obvious screws or anything to open up. It looks like I can prise off the rear light, but has anyone attempted this before or is it a closed unit?
Have you looked under the feet ( feet come off with a 1/4 twist )
Tho more than likely it needs those special snap tools like most electronics these day.
How about just placing in a black plastic bag in sun for a while...good luck
CircusAnimals
Thanks.
Removed the legs but no obvious screws.
I can try to tempt them out, try the plastic bag trick on the rest, and spray around it next time, but I’m thinking there may be eggs inside so keen to clean it out.
z0idarlo
3 screws under the sticker (under feet) need to be undone, then the bottom pulls off (with care to avoid yanking ribbon cable).
  • 5807 Views
