  • 4 Replies
  • 2864 Views
marietamicheva
Can you tell me is it possible to use the Arlo Baby witout WIFI and use the mobile network 4G LTE .
Because i can only use the camer if i am in the house outside the house i can't use the camera .
So if it's not possible to use it without WIFI how can i extened the WIFI coverege enough so i can see the baby at least in 5-6 meters distance ?
If your running a mobile hot spot ( LTE/4G modem outputting wifi ) you can link the Baby to it.
marietamicheva
@TomMac i can't connect it wants only wifi it doesn't regognize my hotspot i cannot login in the app without using wifi
LK1991
How??????? Details please
ShayneS
HI @LK1991
Your device should be broadcasting an SSID "name" and you may have a password on the device or your provider can assist you. You will connect to it as you would your router.
  • 4 Replies
  • 2865 Views
