Can Arlo Baby play continuous white noise?
Hi! I currently have a baby monitor for my first child where I can add my own micro SD card and play music on a loop for a maximum of 24hrs, which is really handy for white noise and therefore can play white noise throughout the night/naps without having to restart it all the time or have ANOTHER device playing white noise.
So does the Arlo Baby have the ability to play white noise continuously for at least 12hrs? All I can see is that you can loop and set a timer for 3 hours, but this is obviously not enough for a full night.
Thanks!
Yes it will play continuously....
pick the white noise clip and play, then the " circle with 1 " icon.
it will play till turned off
or if set, till the timer runs out
Arlo Baby
